PDA
View Full Version : Heads and Cylinders
Pages : [1] 2
  1. head bolts
  2. hole in head
  3. Machining the head/ Boosting compression
  4. Best source for 8 mm head studs...
  5. Head gasket fit on the China 2 stroker
  6. ThatsDax "65"cc Head Bolt Torque
  7. Head Leak
  8. Round or Square head design
  9. Cylinder head bolt specs?
  10. 49cc HT bicycle engine head stud length?
  11. Head bolt torque
  12. head gasket questions
  13. Transfer Port Modification- Pictures and results here.
  14. Silicone on Head Gasket?
  15. New Slant Heads for 80cc's: Compression Boost!?
  16. Help- Tightened head bolt too much!
  17. slant head was fun while it lasted...
  18. Thoughts on the "slant plug head"
  19. Metal cylinder head gasket
  20. Does this problem sound like a blown head gasket??
  21. Head Gasket Gap On New Engine?
  22. No head gasket?
  23. Anybody have luck removing head AND base gasket?
  24. new head
  25. head gasket trouble
  26. no head gasket
  27. Blown head.
  28. Engine head bolts-ARE YOU KIDDING?
  29. Mounting a Slant Head?
  30. Oil on Head
  31. Does slant head orientation matter?
  32. Head Gasket ??
  33. turning the jug( head ) around???
  34. Head bolts
  35. Milling Head???
  36. The Basics, Port & Polish and Port Matching
  37. 48cc head 66cc
  38. 6mm head bolt engine vs 8mm head bolt engine?
  39. 2 head gaskets?
  40. Head bolts
  41. High Compression Head
  42. Grime on cylinder head
  43. Broke my headbolts trying to put a slant head on a regular block... Crap
  44. Changing stock head to slant head
  45. head bolt torque
  46. can I put a slant head on my engine that has 6mm head studs?
  47. Porting
  48. Angle Plug ( Slant) Head Question.....?
  49. Damn head bolts!!!
  50. Slant Head
  51. Can I reverse slant head
  52. Allen head bolts
  53. head gasket leaking
  54. oil on top of the head
  55. jims billet head preformance review
  56. rotating the slant head
  57. slant head dead
  58. The Squish Factor
  59. liquid cooled ht bicycle engine
  60. Head bolt Question.
  61. Puch Moped Head on HT 67cc bicycle engine- thanks Foureasy!
  62. Head Gasket Blown (I guess)
  63. Solution to photos of my blown head cover
  64. So far, I've had good luck running...
  65. 2 head gaskets or just 1? PK80
  66. How to make a cylinder gasket?
  67. Woot just got my first dremel.
  68. ive duhsploded my piston rings!!
  69. Where is the best place to get a slant head?
  70. billet head- very nice!
  71. Piston slop - lmao
  72. Slant vs. Straight Plug Motors
  73. Electro plated piston rings - Has anyone tried these?
  74. Blown Head Gasket With Pictures
  75. Which way does the slant head go?
  76. It Does Matter!!!
  77. Connecting rod clearances and play?
  78. Needle bearings or Bushings, what's your choice?
  79. big bore kit?
  80. Wrist pin keepers, How to remove?
  81. can you rotate the jug 180 for carb in front?
  82. Cylinder Head - Temperature
  83. How does this plug look
  84. Replacing head gaskets
  85. Creatives Billet Head
  86. Chrome slant head and plug?
  87. Spark Plugs???
  88. Send me all of your crappy stock plugs!
  89. Question about spark plug heat range
  90. why to not use a slant head...
  91. Blown gaskets???
  92. Which direction is best to mount a slant head?
  93. head stud lenght
  94. A Question to Ponder
  95. convert a 48cc to 66cc???
  96. blew head gasket already
  97. Mounting cylinder backwards?
  98. head gasket and silicone sealant
  99. bike makes strange noises
  100. My Bike wont start.
  101. New 49cc POS HT Bicycle Motor
  102. blew my motor at the lights :O
  103. Minarelli Cylinder.
  104. using generic brands on skyhawk??
  105. What is a slant head
  106. Can a cylinder body be replaced without special tools?
  107. Cylinder Head Lapping Question
  108. what performance cilinder kit match with my 66cc engine?
  109. Making Stuff from Garbage
  110. Thinking about an aftermarket connecting rod.
  111. Dimples on the Piston Skirt
  112. How do I get the gudgion pin clips back
  113. piston swap
  114. Transfer port questions
  115. J b weld Head Bolts
  116. Timing vs performance
  117. my destroyed piston...
  118. Head gasket,head ache
  119. Jug bottom gasket install
  120. What's your cylinder head temperature?
  121. help with rings and cylinder for gt3 55cc
  122. Head torque
  123. gt5 piston rings
  124. Spark plug threads in head stripped
  125. Ran but now locked up
  126. can you turn jug
  127. Repair Pistons and Cylinders Using Alumiweld/Alumaloy/HTS-2000 (Experiment)
  128. Difference between slant angle head and normal
  129. pk80 or gt5 .160 piston fit in raw motor .100 piston with manic mechnic head ? HELP
  130. this may be a dumb question
  131. new bike cylinder wont move-help!
  132. parts is parts
  133. No start if no base gasket, no head gasket?
  134. Scored Piston - broken Piston ring -- twice!
  135. There go my rides to the beach
  136. Buildup on piston and head
  137. New Manic Radial Head
  138. Manic Mechanic Gen II Head Installation
  139. show off your piston mods!
  140. steel lined cyliners
  141. Slant heads with squishband
  142. Finally got that head bolt fixed
  143. manic mechanic head or pirate head
  144. Replacement cylinder Jug
  145. Cylinder bolt hole measurements
  146. bad compression!
  147. question for a machinist about 2 stroke heads
  148. New Motor - gaskets Q
  149. Piston trim on exh. side crown
  150. What a Noob Did To His Head and Cylinder. Grind, Polish
  151. Did my 66cc motor come with a 50cc head? Is yours like this?
  152. rotating engine barrel ,pros an cons
  153. cylinder 66cc casting fault
  154. honing a cylinder
  155. Bad top end.
  156. Replacing head bolts with gasket?
  157. Piston install help
  158. How to insert a piston in a China Girl Motor
  159. cylinder dimensions?
  160. idk help torqueing head bolts
  161. SkyHawk Connecting Rod Question.
  162. Is it possible to 180 the cylinder?
  163. New cylinder bolt question
  164. I have a stupid torque question....
  165. Piston ring broken, can't find seller?
  166. Lawn mower plug head (what)
  167. Flying Horse Piston in a Grubee Motor
  168. sanding the head
  169. Cylinder Base Gasket/Permatex Ultra Blue
  170. Acorn nuts will destroy your engine
  171. Minimum CC's
  172. Reed Valves
  173. Puch head on a 66cc HT bicycle engine with 6mm studs
  174. Double ended cylinder stud
  175. 2009 66cc Flying Horse, needle bearing or brass bushing?
  176. which way should the piston ring end gaps should face?
  177. 69cc?
  178. big bore kits for 2 stroke engines
  179. Successful puch head mount
  180. what did i do wrong
  181. plastic piston rings, carry a spare
  182. How bad is a very small head gasket leak?
  183. Head Tuning
  184. Wrist pin stuck, 66cc HT bicycle engine
  185. Head stud replacement
  186. Are GT-5 replacement cylinders available?
  187. Is this new cylinder ruined?
  188. URGEND! Piston Clip Question
  189. does the 66cc cylinder head fit the 48cc motor?
  190. Finally figured out wht my motor wouldnt tune
  191. PC high compression head
  192. Look at my Cylinder walls
  193. Piston Messed Up
  194. Leaking top cylinder body cap
  195. Piston Rod Question
  196. Head - slight compression loss through gap
  197. Gap in Head Cylinder
  198. What is the best head to purchase?
  199. Look at my cylinder and tell me whats been happening...
  200. CRM stage2 vs RSE stage 3 head????
  201. spark plug oil leak...
  202. Arrow on top of piston.....
  203. Head Nut torque Specifications
  204. cutting piston skirt... even more??
  205. 350 mile cyl teardown.....
  206. Angle plug head forward or back diff in power???
  207. Im dumb: some easy math
  208. Oil on front of motor
  209. re-occurring cylinder prob
  210. questions regarding mods to china girl motorized bicycle
  211. Spark plug help
  212. Piston blocking exhaust @ BDC
  213. A few more chips from cylinder?
  214. cylnder head laping/ flating
  215. Compression Problems
  216. size of puch head
  217. Compression Question
  218. Needing spare parts, Please help
  219. possible solution to constantly retourqing head bolts
  220. Top end rebuild
  221. PC high compression head piston sound like its hitting the head
  222. Slant cylinder head vs. strait cylinder head
  223. High Compression Head
  224. Loss of power when engine hot...
  225. Performance mod - Polished Head???
  226. Where to get better crank bearing seals?
  227. Threaded Rod as Head Stud replacement
  228. third transfer port reed kit and porting 66cc
  229. Double Jug Gasket???
  230. Piston needle bearings vs bushings?
  231. Using single piston ring
  232. possibly good head...
  233. shorter head on 66ht
  234. Installed puch head, now cant get it to run well...
  235. 98cc Haad Gaskets
  236. Help is my Cylinder RUINED or NOT?
  237. spark plug?
  238. TQ specks?
  239. can this motor be repaired?
  240. Can't torque Puch head
  241. Super Rat Body
  242. Internals sticking
  243. Piston rings in the way of sliding the jug on
  244. Tight Brass Bushing Question
  245. Hf 79cc ptv clearance
  246. Newbie head torque Q's
  247. After Market Heads Better Cooling
  248. head gap. help!
  249. Custom Billet Head... I haven't seen this one
  250. just wanted to share pic of head I got in today from Dax
