PDA
View Full Version : Lighting and Electrical
Pages : [1] 2 3
  1. Tester for ignition
  2. norman's white wire motorized bicycle head light
  3. Bicycle lighting???
  4. light system for your bike
  5. Kill switch and light question
  6. can i get a light?
  7. head light battery?
  8. Kill switch repair. yellow button
  9. Solar Head light
  10. My Kill Switch has a Black and Yellow Wire??
  11. Keyed Ignition Switch Install
  12. ...more than a head light??
  13. 6 volt LED Headlight Information
  14. Shock resisitant light bulb
  15. Norman's small light
  16. White wire, headlight, elctrical stuff
  17. How many amps is my light using?
  18. Lighting Accessories...
  19. Simple Turn Signal Circuit
  20. performance spark plug?
  21. turn signal lights
  22. white wire powered light
  23. Charging System For Lights
  24. Running 12 volt car lights
  25. tail light/white wire ?
  26. Normans Light review
  27. 6 Volt Light Question...
  28. Lighting System
  29. A light subject
  30. Brake light switch for dual pull brake handle
  31. Spark plug modification.
  32. 24 Volt Light
  33. Magneto rewinding
  34. Need headlights? Just Tap 'Em
  35. I need a stop light, not a tail light
  36. Zoombicycles light, generator kit
  37. Front Mounted Strobe Light
  38. Dynamo Light Set - Ebay - Any good
  39. Need socket for this light bulb - where to look
  40. how can i make this light brighter?
  41. Tail Lights
  42. generators for head and tail lights
  43. Were can I find a rear rack mount light????
  44. 12 volt light
  45. Brake switch replacement
  46. head light
  47. Self powered light kits? Disc brakes on cruiser?
  48. 6V lights/run/turn/brake/circuit help
  49. Bike World 6volt light
  50. Iridium Ngk Spark Plug
  51. Electronic Speedometer made into a tachometer
  52. solution for problems with electronics on motorized bicycles
  53. possible solution to the light problems
  54. Head light/Tail light
  55. Cheap light set
  56. Bike Light
  57. any ideas on how to rig up turn signals on a motorized bike?
  58. White wire? How much juice?
  59. Interesting Brake Light I found
  60. tail light score!!!
  61. Replacing stock ignition wire
  62. Gutting the muffler and headlight, tail lights..
  63. light sugjestions?
  64. what is the best value in lighting
  65. Homemade turn indicator attachment!
  66. changing cdi cable????
  67. Head light help
  68. Cheapy Ebay light sets..
  69. question about battery & lights
  70. Simple LED head and tail-light circuit
  71. How long will my battery last with this light per charge question?
  72. expensive cure for cheap china coil
  73. AC to DC
  74. Super Dynamo LS-1 lighting kit from Wonderful creations?
  75. Actual Working Tail Light
  76. Motor lighting generator kit
  77. Question on 12 Volt Lighting System
  78. Please help me to connect them
  79. Electrical Guru's Needed , Thoughts Wanted
  80. Turn Signals
  81. 12 volt stator
  82. has anyone tried one of these E-3 spark plugs?
  83. Please Tell Me I'm Not Crazy
  84. lighting
  85. Flying Horse Magneto
  86. A quick fix to our lighting woes????
  87. I know this isint an electronics forum but.....
  88. looking for a 3-6" diameter headlight
  89. Lighting Kit for motorized bicycles
  90. Engine ONLY RUNS if white wire is grounded to frame!?!
  91. Nice LED lights to run off the white cable
  92. Flasher Kit
  93. 6 Volt Battery charger
  94. How do Kill Switches work?
  95. White Wire Voltage Question
  96. Bicycle Carbide Lamps STILL in manufacture!!!
  97. so anyone know how to make one of these
  98. Stock sparkplug connector
  99. A WHITE WIRE SOLUTION!!!!! Finally
  100. simple lighting system
  101. Help with RF inference
  102. 12VDC system thoughts
  103. Angled Boot for a slant head
  104. LEDs and the infamous White Wire (Questions)
  105. BP5HS Vs BPR5HS plug?
  106. Different Idea for running Speedo wire
  107. Where to find a tach?
  108. Spark Timing?
  109. Turn signal switch?
  110. BRIGHT headlight powered by engine needed
  111. LED Rear light not working when engine running.
  112. turn signal switch options
  113. Bicycle blinking LED light not working with when motor is on
  114. turn signal switch
  115. Internal generator for 49cc
  116. Christmas Lights Etc
  117. BRIGHT lighting system idea
  118. LED Camera lightas using AA's
  119. 60W of LED light, using only 1.2 amps of power.
  120. Vintage LED Taillight / License Plate Bracket
  121. kill switch or not?
  122. Problems hooking up Wonderful Creations 6V charger
  123. Wiring question
  124. LED Landscape Lighting good for Headlight?
  125. Question about this taillight
  126. HT Bicycle Engine Generator Characteristics
  127. EZ 10 amp fricton drive dynamo
  128. generator or alternator add on
  129. White Wire Light System
  130. Sturmey Archer X-FDD Dynohub/Drumbrake Experiments
  131. Lights and Generators?
  132. saw this 12 volt on ebay. any 1 tired it??
  133. new Magnecor plug wire/help and tips pleas.
  134. Can I make this system work?
  135. Possible lighting solution
  136. Re: novice who needs help
  137. howd you guys solve this problem
  138. Model aircraft CDI/Hall sensor ignitions for China girl engines?
  139. testing a magneto?
  140. Custom LED Light project ($2 total cost in parts)
  141. vintage stacked headlights, sort of
  142. CDI Test
  143. New Spark plug wire or how to ruin a CDI
  144. Kill Switch
  145. HF greyhound electrical, please help :)
  146. The total package inquiry
  147. Hour/Tach Meter
  148. Homemade lights are the best
  149. Roll Your Own CDI
  150. Mag Rotor
  151. ultra noob CDI question
  152. The 6v White Wire Question
  153. battery/light question
  154. Magneto
  155. Coach Taillights
  156. HF 52cc Kill Switch
  157. Install bike night?
  158. light system for 4 stroker?
  159. Dreaded White Wire - 6V 30W Spotlamp?
  160. ccs to watts
  161. battery power?
  162. Racing CDI how to install?
  163. Need Electrical Help
  164. Where do I find one? Magneto Question
  165. New style CDI????
  166. switches that fit in the bike lever?
  167. Odometer, speed odometer, bike computer, does not work when engine is running
  168. Will a 12v generator make your engine explode?
  169. Need help with chrome headlight
  170. Will it hurt to hit the kill switch while coasting?
  171. Wiring and confused
  172. LED bulb upgrade,
  173. how to change plug wire
  174. Lighting (see Section 316.2065, F.S.)
  175. Light Lane
  176. New cdi&mag.. no spark still? what next?
  177. Analog Tachometer In Testing
  178. Possible Dynamo and Battery Set-Up
  179. brake switch
  180. cdi
  181. Calibrate that cheap speedometer
  182. Charging a cell phone via USB?
  183. Lighting Question
  184. I just order 2 of these babys! (best rear lights ever NMO)
  185. Anyone ever order a BGF headlight?
  186. Simple 12v Chargeing system.
  187. LED Light System - Engine Gen Powered
  188. 2010 NiteRider MiNewt Mini-USB LED Headlight w/Li-Ion Battery
  189. Miller light
  190. Very Bright LED Headlights
  191. How do you wire the vintage kill switch?
  192. Cheap CDI
  193. $5 Light Pretty Darn Good for Scotchmo Circuit
  194. High & Low Beam Headlights
  195. turn signal lights for bikes
  196. turn signal lights for bikes
  197. A really nice headlight.......
  198. Lighting system for motorized bicycle?
  199. Charge while riding?
  200. Maxxon Brake Light
  201. Idles, but does not run under load
  202. magneto is dead?
  203. need help on how to wire an ignition
  204. Adjustable Timing Magnet
  205. Running a Refrigerator off the White Wire
  206. magneto burnt out again
  207. remove spark plug wire grubee gt5 skyhawk
  208. 500 - 1000 lumen Super Bright Led bike lights
  209. Car alternator?
  210. A couple questions
  211. Where can I get these lights?
  212. help on making or buying a strobe circuit for my tail light
  213. Can anyone help with dimensions?
  214. Plug Gap tests on GT5 results
  215. Thoughts on this brake light?
  216. Princeton Tec EOS BIKE Headlight
  217. Bicyignals "Indicators" Review
  218. Step-by-Step DIY Rectifier Instructions
  219. Generator for Trike lights using 2.5 hp HF engine
  220. Pic: My Wiring
  221. Hotter ignition for the GT5R?
  222. ???? 8W 750LM 12v Led Headlight ????
  223. Headlight Question.
  224. Wiring Trouble (last thing i need help on)
  225. R/C Plane CDI - Hall Sensor Questions
  226. Brightest portable,rechargeable Flashlight/Headlight (in my opinion))
  227. Speed/Tach/Temp/Everything-Ometer!
  228. Ignition Breakthrough/secret of the white wire
  229. cdi replacement
  230. Bright Enough??Planet Bike Super Flash Turbo
  231. headlight
  232. just finished assembly on bike no start
  233. CDI woes...
  234. Good idea to solder spark plug wire to CDI?
  235. What does resistive carbon wire look like?
  236. Electrical Kit build progress
  237. Mounting Front Turn Signals: Suggestions?
  238. My kit didn't include a kill switch
  239. What's the best head light I should get?
  240. I want some lights
  241. USB Port
  242. spark plug wire/boot crapped out!
  243. wireing
  244. Arduino based small engine ignition controller
  245. more solid state ignition systems. using hall sensors
  246. Always Do It Yourself!
  247. Homemade headlight under $10
  248. 8W LED light result *** LINK ***
  249. wire problems
  250. Ignition issue
