PDA
View Full Version : Hubs, Gearboxes, Sprockets and Chains
Pages : [1] 2 3 4 5
  1. Sprocket Installation - Bicycle Engine Kit
  2. motorized bicycle 44 to 36 tooth sprocket swap
  3. Motorized Bicycle Chain size ?
  4. Sturmey Archer hubs
  5. (front) drive sprocket removal
  6. how to remove chain link
  7. need help with shift kits and drifters
  8. jackshaft kit
  9. Where can I get ono of those heavy duty rear hubs?
  10. 68 Spoke Rim Split Collar Sprocket Adapter
  11. HOOT GearBox replacement?
  12. Just a thought Nuvinchi hubs
  13. check out this transmission
  14. my tranny seized!!!!!!!!!1
  15. Transmission Mod Question
  16. Internal Gear Hubs - rear sprocket ate dust cover
  17. Sprocket Installation With coaster brake
  18. will a sturmey archer 3 speed hub hold up to motored biking?
  19. running gear oil in hoot box
  20. List of motorized bicycle gearboxes
  21. Sprockets *How Many Teeth*??
  22. CVT 7 : 1 Tranny from Monster Scooter Parts
  23. centrifugal clutch install gone bad.
  24. upgrade for stock 415 chain?
  25. 40 Tooth Sproket Vs. 36 Tooth
  26. Pros and cons of dynamo hubs & lights?
  27. what kind of hubs does Worksman use now?
  28. nexus intra 7 SG 740
  29. jackshaft bearings
  30. 41 tooth to 32 t sprocket
  31. Rear hubs with rims complete set ups
  32. Internal 3 speed wheels (Hubs)
  33. Staton gear box bearings shot !
  34. chain sizes
  35. Shift Kit - Best Gear Ratio?
  36. spookytooth gearbox for r/s 35cc??? yes please!
  37. Anyone looking for heavy duty #41 chain?
  38. Bottom bracket as jackshaft
  39. Upgrades Made to the SBP shift kits?
  40. transmission
  41. shimano hubs
  42. Replacing Hoot Gearbox
  43. inside the nuvinci hub
  44. CVT Tranny on a Happy Time Motorized Bicycle
  45. SBP Shift Kit
  46. Sprockets?
  47. Got a Hub Issue Now??
  48. Strange Shimano Hub
  49. sprocket clearance
  50. Is it just me , or is...
  51. Phaser Gearbox
  52. EZ Motorbikes new tranny.....
  53. Front SBP chainring wear
  54. Heavy Duty Axle Kit
  55. jackshaft kit
  56. Automated speed calculator
  57. The new Shimano Alfine SG-S700, 11 speed!
  58. using only one chain
  59. Spring loaded tensioner questions
  60. Clutch question etc.
  61. Question about drive chain pitch
  62. transmission oil
  63. centrifigul clutch
  64. lower gearing for a single speed?
  65. Internally Geared Hub (ie Sturmy-archer) not necessary when you have CVT?
  66. Jackshaft-ed Rearmounts Anybody Have or Try?
  67. Where 2 get jakshaft in oz????
  68. Rear Drum Brake Sprocket Adapter?
  69. EZM clear cover
  70. Best Jackshaft kit?
  71. Took my rear hub apart today
  72. Universal rear sprocket kit -parts dimensions needed-
  73. Where can I get new drum brake/2 sprocketed Moped hubs
  74. #25 Chain & HF 52CC WaterPump
  75. Can someone check my math?
  76. I calculated my gearing to speed
  77. Seems to be a lot of wear on my crank gear
  78. Sprocket cover maintenance
  79. chain tensioner
  80. Clamp rear sprocket on 3-speed
  81. Stage III gearbox vs 4G belt drive
  82. Where can I buy a hub adapter?
  83. derailer problems
  84. NuVinci Hub + SBP Shifter KIT having BOTH is REDUNDANT!
  85. name this gearbox
  86. Flip-Flop Hub Sprocket Mount
  87. Gear Reduction on the newer model HOOTs
  88. 76mm clutch compounds????
  89. I just put on my new 56 tooth sprocket and the chain keeps falling off even tho its..
  90. Is there anyway to get a 4g 5:1 belt drive to work with a 44t sprocket?.
  91. weird clutch "problem."
  92. Unlock 1.25 Friction Roller?????
  93. grubee stage III gearbox can that lockup?
  94. mini dirt bike sprocket to a BMX hub?
  95. Sprocket Beatification It's so easy
  96. BGF Left/Right Freewheel Axle?
  97. Skyhawk Stage III Crank Case Binding
  98. Rear hub?
  99. 49cc Clutch Removal
  100. better open up yer new hoot chainbox!!
  101. replacing sproket and chain with bicycle set
  102. please help with gearing..
  103. sproket adapter
  104. Vendors for 68 spoke sprockets
  105. what sprocket should i use?
  106. EZ non invasive tensioner securement
  107. Front Freewheel ?
  108. Looking for a certain sprocket, anyone got a vendor?
  109. sbp shift kit ??'s
  110. ~~chain tensioner & hub adapter~~
  111. 11 t freewheel maintenance??
  112. ISO 6 Bolt Adapter - Will this work as a sprocket adapter?
  113. How do you remove this crank arm?
  114. clutch gear wobble/rattle?
  115. Bike rear sproket attachment
  116. sproket adaptor
  117. 110 mm spacing Internal gear Multi-speed Hub
  118. How to Upgrade your Bicycle Crank
  119. Mounting sprocket on a bike with a coaster brake
  120. Sprocket question about weight load
  121. HONDA GXH50 and GRU-BEE STAGE III best oil?
  122. Would Jackshaft = easier/better way to transfer power to rr wheel?
  123. Shift Kit and 3 speed hubs
  124. grubee hd hub question
  125. A New Idea
  126. internal gear hub help.
  127. Sprocket size for my Trike
  128. Sprocket too big for hub...what to do?
  129. cogs for NuVinci hubs :).. 3/32'' nine spline.
  130. Hoot gearbox proper gear indexing help please
  131. NuVinci hub out of the box!
  132. What's he doing?
  133. gear ratio help
  134. longivity of a chainbox??
  135. Sprocket Adapter Question??
  136. tav2 need rpm reduction
  137. Couple questions about rear drive set up.
  138. Rear hub problems :(
  139. 11 Tooth Sprocket
  140. what is the best rear hub set up
  141. Chain alignment
  142. Please help me get the best sprocket ratio
  143. What Is the Best Hub - Sprocket Solution for 5-7 Speed Freewheel Bikes
  144. Clutches
  145. Clutch problems
  146. what gage spoke for NuVinci n171b hub?
  147. shift kit shifters
  148. custom freewheel
  149. Gear ratio: Specific Torgue Question
  150. help hub bolt
  151. 3 speed hub schematic?
  152. How to Install Coaster Brake over Manic Mechanic Sprocket Adapter
  153. Differences between freewheel & solid HD sprockets?
  154. nexus in hub 7 speed with drum brake
  155. Nexus 3 speed Hub 36h
  156. Something wrong with clutch
  157. hard core chain vibrations
  158. Unusual Clutch Pad Wear
  159. Need help with centrifugal clutch
  160. SBP shift kit for cantilever Schwinn?
  161. #41 chain and flying horse engine?
  162. 8 tooth?
  163. Return spring?
  164. large rear sprocket
  165. spring loaded chain tensioner
  166. which wheel/hub will work with a sprocket hub adapter WITHOUT coaster brake
  167. drive sprocket bolts
  168. GruBee Stage III Gear box lubrication
  169. need advice on drivetrain modification
  170. SBP shift kit performance mods
  171. rear sprocket wobble.
  172. Nexus 4-speed thoughts?
  173. Clutch lock
  174. In need of advice on a bucking bar ball mistake
  175. Proper chain breaker?
  176. DIY alternatives to the sprocket rag joint?
  177. Alternate/custom sprockets
  178. hub brake on cruiser
  179. Changing Engine Sprocket
  180. single gear question
  181. NOW WHAT? gearing choise help/ ideas
  182. Rear Sprocket Mount
  183. Weld 76mm Clutch Spring?
  184. Help Please. 6.5hp HF
  185. AGK(GTC) 100X CVTs
  186. Help with clutch ....
  187. 3 speed internal hub for SBP shifter... recommendations?
  188. Nexus 3, 4, 7 or old Sturmey Archer?
  189. Sbp shift kit crank???
  190. Centrifugal clutch question
  191. Shimano CBE 110 axle problem
  192. shift kit question
  193. sprocket
  194. Running without a clutch cover, probably a bad idea?
  195. Chain and sprocket problems
  196. Rear Derailleur for MT Motorized Bicycle?
  197. Bucking osselation & 'Raao' sound in high gear (shift kit)
  198. What size sprocket to change to?
  199. 410 vs 415 Chain / Info
  200. help with shimano 8-sp rear sprocket
  201. 4G T Belt Transmission Only (78mm
  202. Thumb lever clutch
  203. I'm having a problem with my clutch lever and lock.
  204. DIY homemade clutch lock
  205. Chain Scrubbers with 415HD and #41 chains
  206. Disassembling cassettes
  207. Clutch Assembly-Wrong cable supplied with kit?
  208. Offset pedal crank
  209. Whats a good Gear ratio for a 6T front sprocket
  210. Sturmey Dymo-Hub Questions
  211. alittle help with the crank and sprocket
  212. Sprocket rubber
  213. Sprocket open to small for the drum!!! help!!!
  214. Bug gen out need a new gearbox
  215. *vid* Perfect sprocket alignment every time, how easy is this??
  216. Internal geared hubs, Whats good,What ain't
  217. rear sprocket orientation
  218. Source of new clutch pads
  219. Squealin clutch
  220. What's it like running a 36T sprocket?
  221. 2 stroke pullstart kit installation
  222. shimano cb-110 help
  223. sproket question
  224. Pulled the trigger...hub adapter ordered.
  225. Sprocket Adapter Vendor?
  226. Shift kits questions
  227. My Rear Hub Self Destructed (pic)
  228. Source for front sprocket to fit 415 chain
  229. Sprocket mounting bolts
  230. Anyone ever have clutch gear cracking problem?
  231. hub drilling
  232. Rear sprocket size??????
  233. MM Hub Adaptor.. Total Loss or repairable??
  234. Chain help! #40 too big, #41???
  235. 10 or 11 tooth 5/8 bore sprocket???
  236. Rear belt drive?
  237. Automatic 2 Speed
  238. Chain size chart
  239. Sprocket adapter installation
  240. Big bevel gear question
  241. Will a 410 chain fit Manic Mechanic Sprocket and Adapter Assembly
  242. HELP!!! Clutch pad problem/question
  243. Skyhawk chain won't fit MM sprocket
  244. Woodruff key size
  245. Centrifugal Clutch Instructions Available Here
  246. Gearing Calculations..how to figure
  247. Freewheeling Crank Assy ?
  248. Chain Lube ?
  249. I need disc rear hub, 48h
  250. Which sprocket should I get
