PDA
View Full Version : DIY Home Built Motorized Bicycle (non kit)
Pages : [1] 2 3 4 5
  1. weed eater bike questions
  2. Way to run headlight off weedeater motor?
  3. Homelite Super XL 925 Chainsaw
  4. so what happens
  5. Friction Drives
  6. Do I really need it
  7. How to Build a cheap friction drive bike
  8. DIY motorized bike missing gear
  9. help out a fat man
  10. I did a stupid thing again
  11. home brew
  12. another question from the villiage idiot
  13. Centrifugal Clutch Friction Drive
  14. Chainsaw masacre
  15. Look at this cool homemade bike
  16. welcome to my world
  17. friction drive wheels..
  18. how about we all
  19. first bike builds and some questions
  20. Arggg...another one bites the dust
  21. Briggs and Stratton Bike
  22. Im thinking
  23. Da 2 headed monster
  24. are they all this easy...
  25. I stand corrected...
  26. need advice on weedeater powerd bicycle
  27. The best thing I have learned so far
  28. All things mtb
  29. Need some help with my 1st build!
  30. I need some advice
  31. Whats the least amount you can spend?
  32. 25cc bike
  33. Compression PSI 25cc vs 32cc
  34. Questions
  35. what would happen...
  36. Da Mutha of invention
  37. ready (???) to put plan into action!
  38. Feedback
  39. I want a trike
  40. So I have been sick for 2 weeks
  41. Frustrations and Confusions
  42. Just add engine?
  43. Pure Brilliance...
  44. 3.5 HP small lawnmower engine
  45. Left Handed Nut solution?
  46. The project begins
  47. Weed Whacker Bike tips
  48. Weed eater mountian bike
  49. 1901 friction drive
  50. autopsy of the bolens 31cc WW engine
  51. BMX Build
  52. need chain buying advice
  53. I Need a clutch
  54. I wonder how
  55. What is it about dyi bikes
  56. Gear Ratio??
  57. need guess, educated guess or swag
  58. weed eater friction drive question
  59. weed eater muffler mods
  60. always look a free weedeater in the mouth.
  61. Pocket Bike Engine Throttle Cable?
  62. moped scooters in nc
  63. my ultimate project
  64. Coaster to Drum Conversion
  65. just my opinion.
  66. Good places to get Trimmer parts?
  67. Da demo bike
  68. Tri-cycle Builds
  69. how to advice needed - friction drive
  70. helper engines.
  71. two failures
  72. clutch?
  73. "performanace" weedeaters?
  74. Chopping up a bike crank arm.
  75. hey joe
  76. homelite tear down and cleaning
  77. The book update
  78. motorized kit
  79. All I needed was a Huffy, Duct Tape, and a Briggs
  80. Hey, new guy here. got lot's of questions
  81. every one seems to be different
  82. Madwagon goes to the Park
  83. I did a bad thing.
  84. Magneto problem? McCullouh weedwacker motor
  85. Doing it- friction drive on an occ stingray
  86. My Erector-Set Bike
  87. How to build a transportable motorized bike?
  88. Engine Mounted
  89. a new idea
  90. Bikester
  91. Will a 265 husky thining saw work for a bike?
  92. Clutch action!
  93. What's the best drive roller?
  94. chain saw 2 the sequel
  95. Da Mudder Of Invention...
  96. an ole industrial sewing machine clutch?
  97. So what are the build step for you
  98. Shindaiwa 62cc build- Shift kit, Giant 760... HELP!
  99. what it is bro?
  100. whats it likely 2 do
  101. After the last bike is built...
  102. Bearing troubles :(
  103. Walbro Carb for UT 20537 Trimmer Engine
  104. 3-speed motorbike
  105. Chain saw more resilient?
  106. How would I raise my engine?
  107. tell me which to use
  108. Gravity Clutch
  109. cheap tires for friction drive
  110. Best mounting practice
  111. push more engine
  112. trailers and tires
  113. Ridin' DIY
  114. Need info on a donated engine
  115. the front wheel drive bike
  116. Home built start tips nedeed?
  117. check your nuts and bolts
  118. VeloSolex 3800 Motorbike
  119. key vs set screws?
  120. what to stick in square hole?
  121. Exhaust Noise level?
  122. Motorized Bicycle with a Briggs or Tecumseh engine
  123. mounting kits?
  124. work in progress
  125. Riquimbili?Not a bicycle but you gotta love it.
  126. I'm thinkin' agin
  127. confused about engine, do i need a freewheel?
  128. WW or chainsaw?
  129. Finding parts
  130. emergency brake...
  131. Give you any ideas?
  132. will it hold
  133. new DIY build
  134. I wanna build a Chainsaw Bike
  135. Gasoline mileage on my homebuilt bikes
  136. What the heck
  137. butane/propane tanks.
  138. A couple briggs style bikes
  139. 31cc Ryobi Conversion Engine, and more...
  140. addition to ryobi mount info
  141. A novel approach
  142. Modifying Staton Friction To Chain Drive
  143. Mounting A 44T HT Bicycle Engine Sprocket On The Front Wheel
  144. gears?
  145. Trackfodders bike, finally
  146. Just Got My Poulan 42cc Saw today. Any tips...
  147. Tank advice
  148. throttle
  149. Gear Ratio question
  150. DIY swap shop (true swap not sale)
  151. It is done
  152. Building A Practical And Safe Motorbike
  153. Do you gotta... do you needa
  154. Chainsaw bmx project
  155. China Gal, Too Slow
  156. What's in a name?
  157. Hey Deac and Shoes, ChainSaw?
  158. Gear ratio for scooter?
  159. Two Speed Friction Drive
  160. down to 2
  161. Dangerously fun
  162. Heritage build
  163. DIY Pit Bike 49cc Engine
  164. deacon=robinson crusoe?
  165. Old homelite WW Roller adaption Question.
  166. fuel tank for diy bikes
  167. resurecting Lazarus
  168. Problem with motor.
  169. Chainsaw Bike Project- How to Start engine.
  170. You won't believe this
  171. Gas tanks are us
  172. Roller OD to speed?
  173. Saw test run...
  174. WW
  175. early 1900's clone
  176. check this out
  177. It's raining again so
  178. the shoot bikes don't they
  179. rubber for gasahol service
  180. the 31cc WW Bike revisited.
  181. various weed whacker designs and how they adapt for bikes
  182. questions for the master mechanics...
  183. Ever used an electric generator?
  184. Who's bike and what setup?
  185. homelite super 2 build
  186. freewheel crank
  187. new build in mind
  188. tool pouch
  189. bike parts used for other purposes
  190. New brake
  191. new question for the mechanic
  192. I try something different
  193. 33Saw Broken drive shaft...
  194. also raising the dead
  195. outboard motor bike
  196. 2-stroke, 3hp Briggs scored today!
  197. suggestions please
  198. 1900's Clone
  199. two stroke briggs 3hp -Need clutch
  200. Engines available- 3hp 2-stroke Briggs
  201. carb brainstorming...
  202. 1970s Sears Spyder project
  203. Friction drive clutch or no clutch
  204. so where do I go...
  205. mac 2825 help
  206. Deacon's DIY Electric Bike Forum!
  207. Treasure?
  208. Help... With Mounting (Friction Bike)
  209. Mcculloch Roadrunner
  210. question for the math whiz
  211. Motorized Bicycle Gear Calculator
  212. Any Suggestions How To Install A Twin-Cylinder Engine?
  213. recycled parts and ideas
  214. who's the next Mcgyver....
  215. really really bad day...
  216. Got the 33Saw running, 34 mile roundtrip test ride.
  217. An engine I had forgotten
  218. Gear ratio assistance- 2 stroke Briggs
  219. Good start, banner day.
  220. Your thoughts and comments!!
  221. Honda 5.5 BMX
  222. 33cc SAW 16" Build Log
  223. I thought Id post a link over here too
  224. drive roller help ryobi
  225. Shoe's Winter build thread
  226. Marine Engine Clutch?
  227. What are your thoughts on a Bike Pusher Trailer?
  228. Another new fork in the works
  229. front brake
  230. clutch stuff
  231. Source for 5/8 jackshaft sprockets needed
  232. Another interesting antique to study
  233. Chainsaw carb tune
  234. Fed up with my Poulan 33 Saw....
  235. Picked up another... Tecumseh 2-stroke 3hp
  236. 110cc 3 speed electric start engine ideas...
  237. Noob Help Friction Drive Rollers!
  238. mountain bike thing
  239. 25cc gear ratio
  240. Throttle Cable
  241. Broken Bulb
  242. Monkey Electric
  243. Quick welding question
  244. 24 chainsaw engine motorbike
  245. 2 stroke lawn mower engine
  246. Happy Holidays
  247. Of shoes and ships and candlewax etc.
  248. Weedeater
  249. Weed Wacker Shaft Short
  250. pics of ur drive wheel
