Re: Chain tension wt. rear suspension I don't want to hear it, but I fear you are correct. The first thing might be to try to use a standard derailleur and see if I could use a heaver adjustable spring to actuate it. Then there is the consideration of the constant "push" might cause mechanical problems. Thinking first of the derailluer bearing? Obviously just mounting an engine on an existing frame offers enough alignment problems on its' own to have a dependable ride. Adding my mod would only add to the problem. Appreciate the input. As I haven't bought the bike (and the kit hasn't arrived by pony express from FL) there is still time to try not to shoot myself in the foot. Guess if it didn't work, you could always replace the spring for the rear suspension with a solid link? Jim
__________________ Easy does it, but do it! |
