Old 05-09-2008, 06:43 AM
Bikeguy Joe's Avatar
MODERATOR
Default Re: Hello and of course questions
Originally Posted by Padanew View Post
Hi my name is Padanew. I am interested with learning about motorized bicycles as a way of saving gas and applying my interest in mechanical devices. I already own a bicycle that is still in good shape. I am in good shape with a lot of lower body strength. Which puts me at over 300lbs. Okay, now for the questions.
1. I would like to know who is the best dealer in bike kits?
Dealers vary in there level of service...that'sdax (dacscommm ebay I.D.) is very good with after the sale service, you can't go wrong there.
2. What size engine should I go with?
If you can fit under moped laws in your state you may want a 48cc, but I would suggest the 70cc kit for anyone over 200#.
3. How well does the engine handle hills?
That depends on several factors...A 70cc engine with a stock 44T sprocket and my 200# will pull up any hill we have here in north east Ohio. There are other sizes of sprockets available up to 50T and one guy here sells sprockets in any size you want. Bigger sprocket + less speed, more pull.
4. I have seen some engine models. Some mount inside the frame while others mount over the rear tire. Which is the best and why?
That's partly a personal preference...some even mount over the front wheel, see my avatar. The frame mount kits cost the least, the GOOD rack mount kits a re a bit more pricey, easier to instal and have a little less power, but are generally smoother. You may get differing opinions on this one.
5. Are there any books I could read about to help me to understand more?
I don't know of any, maybe I should write one!
6. What are the most common problems that you run into and how do you fix them?
Intake air leaks seem common, but are very easy to fix and can be avoided altogether.
Some mounting problems can occur, but where there is a will, there's a way!7. What are the rules regarding use in the U.S.A.?
8. Is there anything else you can think of that I would need to know about that I not experienced enough to know about?
I know this is a lot of questions. I hope you can answer them. Thank you for your time and attention.
Also, looky here-this will help you aviod most problems right off and will make your frame mount bicycle motor kit most enjoyable! Bicycle Motor Preperation And Care
