Originally Posted by RedeyeRaab Alright so this is my second build and the first works great, this one not so much. I have tried 2 different spark plugs and 2 different CDI boxes and it won't fire! The wiring is correct and was both times. There is a good flow of gas because when I take out the plug there is a little gas on the end. I have tried just about everything... the second CDI box I know for a fact works because it is now on my first build which I just got done riding. If anyone has any suggestions please help! Also how would I check my spark plugs (check spark?) to se if they are bad?  |
if your cdi is fine...there is two possibilities...magneto....ground....dosconnect the kill switch...check your wire connection...same to same....white wire tape up...check the wires on the magneto....somewhere in that you'll find your problem....good luck and let us know when you are up and running....Dennis
