  #14 (permalink)
Old 07-02-2009, 06:51 PM
2door's Avatar
2door 2door is offline
Default Re: Thats it cauter pin time!
Thanks Terron,
Be careful trying to remove the studs. That titanium stuff might not let you get them out. I've used a grinder and shaved some of the weld bead off the flange, just enough to flatten the nut seating area. Use new lockwashers under the nuts, tighten them just enough to flatten them then double nut. Good luck my friend.
Over Youth and Skill
