Old 06-19-2009, 11:09 AM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: Will This Cable Work As Replacement?
Go to wallmart and buy the bicycle cable set about $5.00 one of the cables ends will fit the throttle end for the end that goes into the carb you can make the end. I show how to make this end in my carb tear down post. Use silver solder and phone wire you will need a propane torch to get the cable and wire hot enough to do the soldering. You will also have extra cables for the clutch and brakes if you need them.
Norman
norms-iron-works.tripod.com
