Re: Running on half choke did you raise the needle a notch?and try it or all the way qnd try it?
mike the needle at the top by the grooves, around 0.070 and at the bottom farthest away from the grooves it should be around 0.065. this is not a hard and fast rule but I've found that some of the needles are not tapered right or not tapered at all.
If they are not tapered right the fuel will be too lean wide open and that is why you need to run with the choke on. |
