Re: does any body have a good carb If you've made a chainsaw carb work, (a Walbro I presume) then you've got the best that can be fitted.
If it's set up right, then the engine should break between a 2 cycle (light to full pull) and break into a rich 2 cycle, or just break into a 4 cycle when in cruise mode.
