diference between bicycle engines?!? Does anyone know the difference performance wise between the wizzer 49cc 4-stroke and the 70cc 2-stroke??
I only know this bout the 4-stroke and 2-stroke:
Engine type Air-cooled 4-stroke OHV single-cylinder
Displacement 49.1cc
Bore X Stroke 41.8 X 35.8 mm
Maximum Power Output 2hp(1.5kw)/ 6,800rpm
Compression Ratio 7.4:1
Carburetor Float Type
Ignition Transistorized Magneto
Starting System Recoil Pull-Start
Fuel Type Regular Unleaded Gasoline
Fuel Tank Capacity .5 Gal (1.89L)
Lubrication System Forced Splash
Oil Capacity 8.48 ounces (250ml)
Engine Oil SAE 10W30
Air Filter Semi-dry
Throttle Twist-Grip
Clutch Automatic Centrifugal
Transmission Shiftless Reduction Gearbox
Final Drive Chain-drive
2 Cycle / Air cooled
70 c.c.
30+ m.p.h.
Manual Clutch
Chain Drive
Thanks
__________________  Sean |
