Old 04-22-2008, 04:55 PM
ran49's Avatar
ran49 ran49 is offline
Default Re: Need clutch expertise.
No,I never have removed my bearings.I did remove the large gear.No puller needed here as it has a sloppy fit to the shaft I think it is only going to run as true as the back of it seats up against the bearing.Although it may not seat against the bearing.Before I took it apart,the large gear had a little in and out play and I forgot to check it after I put it back together.It did have a hump on this rear flange where the keyway was milled out.I filed that flat and put it back together.Still wobbles a little,but chirps a lot less.All I know is it's a beautiful day and I need to do a lot more riding and a lot less fretting.Going on a beer run right now in fact,Ron
