Thread: Carb Jets
Old 05-26-2009, 01:29 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: Carb Jets
Joe
If they will fit the carb then I think they will work ok the threads size on the jet and the jet dia might be right I don't know just looking at them. You could solder your jet shut and re drill it yourself I use a 0.027 dia drill in a hand held pin vice to drill mine. I use a propane torch and acid flux solder you can use resin core solder as well its pretty easy to do and don't take but a few seconds to do. The jets aren't cheap I see.
Norman
norms-iron-works.tripod.com
