Old 04-18-2008, 01:28 AM
Egor's Avatar
Egor Egor is offline
Default Re: Rebuilding your 2 smoke engine
The 6203 bearings are larger all around, and will not work in the 6202 engine. Also if you order the 6202 bearing it has to have the Z, it is a custom size. One of the engines that GruBe was going to sell had a steel sleeve and the larger bearings. It would have been nice to see how long that one would last. Have fun, Dave
PS: One other thing I forgot, there are two bolt patterns for the cylinder, & head I got a 65cc from Dax and none of my other engine top ends will interchange. I know the 48 is small but I thought the 65 would be the same as the 70. If you get a head or a Cyl for the 6mm bolts you can just drill them out to 8mm, or use the 8mm on a 6mm stud, no matter. I did mine.
Originally Posted by Bikeguy Joe View Post
Wow, that's a lot of differences! What's the difference between the 203 and the 202Z bearings?
Chuck - The monkey has the spark plug again!
