Old 05-10-2009, 12:17 AM
shearbf shearbf is offline
Default Re: 68 spoked rim spocket mounting
I just came to this forum so my answer is six days late. I just built a bike with 68 spoke wheels and had to use smaller screws. Get high quality mechine screws,heads are larger than the holes in the sproket,or use washers. This took hours and sore fingers to get installed. Backing plates had to be cut into four seperate pieces and inside rubber was cut into three pieces. Outside rubber had to be tapered from center out to bolt holes. Used hack saw. Once assembled and snugged up it is a tight good fit.
