Old 04-17-2008, 02:26 AM
astronut astronut is offline
Default Re: how to tie spokes
more on tying
1 continue to make loops and pull them tight but not super tight because you will alter the point at which the spokes cross each other, we dont want that. once you have about 4 loops, cross the wire downwards (or upwards if you started tying down). the picture here is very blurry but its the best one I took.
2 once you cross push the wire under and continue to make loops until you only have about 8 inches left, these you can pull VERY tight (the tighter the better). then place the wire across again. it will look like this
3 push the wire under again and it will look like so
4 continue to make loops until you have about 1 inch left. again the tighter the better on these, and make sure they are next to each other with no gaps.
