Old 04-16-2008, 09:08 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: new 65cc motor issues
no goodnic
Is telling you the straight stuff you could even start the idle needle all the way in, I will bet it will stay running then. You can then stop and back it out to lower the rpms. By the way that is an idle adjustment there is no idle mixture screw.
I hope you don't have anymore wreaks or trips to the hospital that's not fun.
Be careful.
norms-iron-works.tripod.com
