Originally Posted by Bean Oil Now all I need is the proper-sized rag joint; I misplaced my original rag joint then ordered another which wound up being a much larger bolt circle and basically unusable without mucho modification. |
For my "rag joint" I used the soles from an old pair of slippers . The material is much thicker than that supplied with the kit . You can put the holes anywhere you want . An other choice is industrial floor mats used to relief foot fatigue . One small mat will provide enough material for several kits . .... D.J.
