Re: Cutting bike/motorcycle cables.... Quote:
Originally Posted by VENICE BOY Use a DREMEL TOOL w/a thin cut-off wheel to cut both cable & housing!
You can also put a dab of solder on the cable end to keep it from fraying... |
The best way!
In a pinch, you can use a bench grinder.
