  #18 (permalink)
Old 04-20-2009, 07:22 PM
Quenton Guenther's Avatar
Quenton Guenther Quenton Guenther is offline
Dealer
Default Re: whizzer ambassador
Hi Guys,
I can help on the oil issues, the leaks, the severe lack of power, and happily pass on information about my Ambassador [version one]. Many have called me about the CVT, but it is important to get the motor running smooth first. The CVT appears to have some possible engineering glitches, but if coupled to a poor running motor it will have a harder time. Most engineers know a CVT eats power, and in order to make it operate correctly often more power is needed.
I had a 100% failure of the compression release [in the head]. After number 5, I replaced the release with a machined 10 MM bolt. I still have a bunch of the compression releases in case anyone wants to do more research.
My Ambassador started much easier without the release. If the pipe starts turning blue near the manifold, check the compression release valve for leaks. If you want to amuse yourself, check the compression, and you will soon see an area than might be modified to gain more power. My NE/SE motors average from 125 to 165 pounds of compression.
you are welcome to call me for additional information and photos
252-475-0406 cell
Have fun,
Quenton
Get YOUR EZmotorbike TODAY!
