Re: Mikuni carb for Whizzer NE5 Thanks!! Its a fun bike!
I ended up going with a Dell'Orto 24mm PHBL carb, as I found that it will fit better than the Mikuni, plus its got a dedicated idle circuit w/ separate idle jet.
The Mikuni 26mm VM carbs all had too large of a manifold mount to make it work cleanly. This 24mm should be enough carb for this engine.
Also, tonight I put the baffle back in the exhaust.. and guess what? My low end came back. The engine likes the back pressure for low end torque! |
