Originally Posted by deacon Joe is right.... make sure you are getting the first two elements then work on the other.... You know you have spark, do you have fuel going into the cylinder. In other words is the plug wet after you try to start it. |
I will ask my buddy if he noticed if it was wet. I know the kill switch on or off made no difference at all.
Reason for my frustration is this motor has a history. It's acted up a few times before. One time the only way I could get the dumb thing to run was keep flicking the lever on the carb up and down. If I left it on down the engine would slow and eventually stall out. I have learned alot more about the thing then I knew before. So I guess that's a positive side to all this.
