  #19 (permalink)
Old 04-11-2008, 05:57 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: Bye bye bicycle :(
Yes Ron I drill onto the frame and either tap or you can drill right through and run a bolt all the way through. You don't need a big bolt a 6-32 or an 8-32 will work just something to keep the tenchioner from rotating in to the spokes. Changing out the low grade bolts is also a good idea. You can also drill the tenchioner and use a # 6 sheet metal screw. What all this does is pin the tenchioner form rotating into the spokes. I have a fix for the bolt that holds the idler form coming loose as well but a guy will need a lathe to do the mod. if you want this mod I can do it. For a small fee. I'll post the info soon and pictures so all can see. sound good?
norms-iron-works.tripod.com
