Re: weed eater bike questions Deacon
to mount that engine take off the flywheel and under it is the cooling shroud and 4 bolts throw the cooling shroud and use the 4 bolts to make your mount
I have the same engine and I stopped cause the carb needs a kit and I'm too cheap to buy one the engine is new and the carb dried out and the diphram is stiff. I had it mounted on the recumbent. I started out with a 7/8 shaft and that was too small in dia. I think about 1" or 1 1/4" might be the way to go but I lost interest in my build so its rusting on the back porch.
Norman |
