Re: How do I shorten the throttle cable? Thanks! I will assemble everything before modifying the cable as eDJ suggests - good idea. After reading all the advice, I thought of another approach that I may try. I may have or can get some brass tubing with the right size ID & OD that I can solder on to the end of the cable. There shouldn't much force on it so this may work. Thanks again. I'll post another reply once I figure out what works. |
