  #9 (permalink)
Old 03-27-2009, 11:48 AM
Traveler Traveler is offline
Default Re: why Grandma, what a big pulley you have
Originally Posted by Ravenshurst View Post
I have been looking at a lot of pictures of pre-war bikes, Monarchs, Whizzers, etc. & I really like that style of bike. I was wondering though, why all belt drive bikes have such large rear pulleys. Good torque, I suppose, but it cuts waaaaaay down on top speed, correct? Not that I really care so much about top speed with a cruiser bike, but I am curious about the size of that rear pulley. If I decided to build a belt drive bike with a chinese engine, would I need a gigundous pulley? Also, I am sure that a belt is quieter than a chain, but it would almost have to be a smoother ride too, right? Any info would be appreciated. Thanks
Ride Safe!
Gonzo
The engine and clutch pulley on the whizzer is relatively large, so the rear wheel sheave pulley has to be way larger. Way back when, I converted a whizzer Pacemaker to chain drive, but the gear ratio was way too high. For the power a Whizzer engine has, the big pulley is pretty necessary. Some of the new bike engines now use chain drive, and have a smaller bolt-on rear wheel pulley and small engine pulley. The existing pulley setup on a whizzer should get you between 25 and 40 MPH, and is still marginal for climbing moderate uphill grades. A smaller rear pulley would produce more top end, but the engine would certainly stall going uphill.
Traveler
