Originally Posted by toytime So what you are saying is that he removed the studs and replaced them with bolts?
If that is the case, that sounds like a horrible idea. You could try to do it while the engine is HOT and use a tool like a "box wrench" or a pipe on your Allan key as a way of giving you more leverage. Be careful! |
He took the bolts that come with the kit and replaced them with the same bolts you use on V brake's to keep em on the frame. I can try heating up the motor but it's VERY loud without that tip..
