Old 04-01-2008, 06:12 PM
TINKERER TINKERER is offline
Motorized Bicycle Builder
Default Re: engine floods its self
I think what was happening was a combo of things, the first thing i had the throttle cable adjustments tight as possible so the slide was resting slightly higher than it should. Second since the slide was much higher than it was supposed to be the idle screw had to be in farther something like three turns out, I re adjusted and everything seems fine, I took it out for a run and it didnt bog at full throttle.
So many potholes, So little time
