Originally Posted by TINKERER My newly installed 80cc kit floods when it sits. yes the fuel line is shut off and you can actually watch the fuel drain into the carb through the line (after about 10 hours) what is going on here? I have to pull the plug and pedal for a while to dry the cylinder out then put the plug back in and it runs like a top. |
The fuel should not be getting past the float valve - if the float is up, the valve should be shut. Suspect trash in that orifice. If fuel is leaking after that and draining the bowl then you need to find out what is open to drain the bowl.
Where is the fuel going? Coming out the main jet? The jiggler?
