  #10 (permalink)
Old 04-01-2008, 02:55 PM
Pablo's Avatar
Pablo Pablo is offline
Default Re: Spark plug wire and boot.
Originally Posted by SeattleMike View Post
How do you guys attach the new spark plug wire to the CDI?
And is there a part number for a better spark plug?
As Ilikea says, there is a screw (sheet metal threads) inside the CDI plug wire hole...just unscrew the old one, screw the new one in. You may need to make a starter hole in the new wire center conductor with a tiny screw or awl or something. Also use some silicone grease or lube on the OD of the new wire. This will help it go in and seal it. (don't use any regular petroleum grease)
