Re: Eliminating the driven sprocket You beat me to it. I was wondering how to freewheel the sprocket. There is some controversy as to whether the derailleur can handle the load, if the rear freewheel fails it would not be fun. I think they make a heavy duty rear cluster. I think you need to check the gear ratio, triple reduction, it just looks like it will have a low gear all around, I could be wrong. I would like to see a small two speed, I was thinking of using some gears from a small Honda the only thing is gears will make the engine have to reverse rotation, a two speed would be easy. A two stroke will run in both directions, years ago my Bultaco at a signal acted funny and when I went to go it only had 4 gears in reverse, it hiccuped and was running backwards. Have fun, Dave
Chuck - The monkey has the spark plug again!
