Old 02-13-2009, 05:48 PM
Pablo's Avatar
Pablo Pablo is offline
Default Re: Fuel issue, topend studder, getting annoyed
Shut the fuel off at the valve.
Disconnect hose at the carb inlet.
Hold the hose in a metal can or glass jar or fuel safe plastic. Turn valve on. Fuel should flow freely.
If no, get new valve. If yes, remove carb.
Take carb off, remove float base. Blow out and clean inlet actuator valve. Assure no gunge is caught.
Clean main jet (sucker should be clean)
Reassemble. Ride. Hard. Shut off. What does plug look like/
