Re: Ontario Canada, MTO info Further searching has been fruitful as I've finally found the federal stuff that is referenced in this part of what's posted on the MTO's site.... "The power-assisted bicycle pilot is authorized by Ontario Regulation 473/06. In this regulation, the legal definition of an e-bike refers to the federal definition of a power-assisted bicycle. For the full definition, please see subsection 2(1) of the Motor Vehicle Safety Regulations under the Motor Vehicle Safety Act"
Here is the text of subsection 2(1) of the Motor Vehicle Safety Regulations Quote:
Vol. 135, No. 8 — April 11, 2001
Registration
SOR/2001-117 29 March, 2001
MOTOR VEHICLE SAFETY ACT
Regulations Amending the Motor Vehicle Safety Regulations (Power-assisted Bicycles)
P.C. 2001-483 29 March, 2001
Whereas, pursuant to subsection 11(3) of the Motor Vehicle Safety Act(see footnote a) a copy of the proposed Regulations Amending the Motor Vehicle Safety Regulations (Power-assisted Bicycles), substantially in the annexed form, was published in the Canada Gazette, Part I, on November 20, 1999, and a reasonable opportunity was thereby afforded to interested persons to make representations to the Minister of Transport with respect to the proposed Regulations;
Therefore, Her Excellency the Governor General in Council, on the recommendation of the Minister of Transport, pursuant to section 5(see footnote b) and subsection 11(1) of the Motor Vehicle Safety Act(see footnote c) hereby makes the annexed Regulations Amending the Motor Vehicle Safety Regulations (Power-assisted Bicycles).
REGULATIONS AMENDING THE MOTOR VEHICLE SAFETY REGULATIONS (POWER-ASSISTED BICYCLES)
AMENDMENTS
1. (1) The portion of the definition "motorcycle"(see footnote 1) in subsection 2(1) of the Motor Vehicle Safety Regulations(see footnote 2) before paragraph (a) is replaced by the following:
"motorcycle" means a vehicle, other than a power-assisted bicycle, a restricted-use motorcycle, a low-speed vehicle, a passenger car, a truck, a multipurpose passenger vehicle, a competition vehicle or a vehicle imported temporarily for special purposes, that:
(2) The portion of the definition "restricted-use motorcycle"(see footnote 3) in subsection 2(1) of the Regulations before paragraph (a) is replaced by the following:
"restricted-use motorcycle" means a vehicle, excluding a power-assisted bicycle, a competition vehicle and a vehicle imported temporarily for special purposes, but including an all-terrain vehicle designed primarily for recreational use, that:
(3) Subsection 2(1) of the Regulations is amended by adding the following in alphabetical order:
"power-assisted bicycle" means a vehicle that:
(a) has steering handlebars and is equipped with pedals,
(b) is designed to travel on not more than three wheels in contact with the ground,
(c ) is capable of being propelled by muscular power,
(d) has an electric motor only, which has the following characteristics, namely:
(i) it has a continuous power output rating, measured at the shaft of the motor, of 500 W or less,
(ii) if it is engaged by the use of muscular power, power assistance immediately ceases when the muscular power ceases,
(iii) if it is engaged by the use of an accelerator controller, power assistance immediately ceases when the brakes are applied, and
(iv) it is incapable of providing further assistance when the bicycle attains a speed of 32 km/h on level ground,
(e) bears a label that is permanently affixed by the manufacturer and appears in a conspicuous location stating, in both official languages, that the vehicle is a power-assisted bicycle as defined in this subsection, and
(f) has one of the following safety features,
(i) an enabling mechanism to turn the electric motor on and off that is separate from the accelerator controller and fitted in such a manner that it is operable by the driver, or
(ii) a mechanism that prevents the motor from being engaged before the bicycle attains a speed of 3 km/h. (bicyclette assistée)
COMING INTO FORCE
2. These Regulations come into force on the day on which they are registered. |
So in Ontario if your power assisted bicycle is in compliance with the above your good to go...if it's not then you may find this bit of text below interesting. The text below is a small part of the REGULATORY IMPACT ANALYSIS STATEMENT that's written below what I've quoted above. Quote: |
The ICBC and Ford Motor Company raised questions regarding the use of power sources other than an electric motor. Ford pointed out that the proposed definition excluded solar-powered methods of propulsion and low-emission combustion engines. The ICBC wondered whether the amendment would allow the use of hybrid systems that combine an electric motor with a combustion engine. The final definition was clarified to eliminate all ambiguity. An important goal of this amendment is to provide a safe, viable, and non-polluting alternative to conventional means of transportation. This alternative means must also perform on a level comparable to that of the average cyclist using a conventional bicycle. A bicycle equipped with an electric motor meets these conditions. Bicycles equipped with a combustion engine are subject to the requirements governing limited-speed motorcycles or motorcycles. The Department will consider amending the definition when other pollution-free power sources become available, at which time it will analyze the impact of such new power sources on the safety of riders and the public.
If you want to read the whole federal government page that contains what I've just quoted above click here
If you want to view the full version of Ontario Regulation 473/06 (re: Power Assisted Bicycles) click here
Cheers...
I refuse to be taken apart...
