  #10 (permalink)
Old 03-28-2008, 03:28 PM
Autocycler's Avatar
Autocycler Autocycler is offline
Default Re: Shaker style choke pull
Originally Posted by ran49 View Post
Here's a larger pic.
I used a 1/8" copper rod I had laying around , beat a flat on one end and drilled a 1/16" hole through it.Used a dremmel to cut a slot in the top tab of the choke lever(long enough to allow full travel). Pinned end of rod between the two choke lever tabs with a piece of wire.Took a thin strip of metal bent in half to form a sleeve and taped to seat tube.Sawed off Shaker peg for handle.
Not the most eloquent solution but sufficiently goofy enough to have a certain appeal.Ron
[IMG][/IMG]
I love your engineering style Ron. This is by far the simplest choke lever I've seen. The Shaker knob is geniusThanks!
Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
