  #14 (permalink)
Old 01-27-2009, 12:09 PM
jasonh's Avatar
jasonh jasonh is offline
Default Re: Gasket and Plug Wire Question
I just use a piece of coax cable I had laying around. screws into the CDI just fine, and is solid copper. I pulled the boot and connector off an automotive wire, and soldered the connector to the coax and slipped the boot on. Works wonders. Might cause some issues with electronic speedos though.
As for the gasket material... You should be able to find some at Advance Auto, Autozone, Checker, etc. I got mine at either Checker or Advance, I don't remember. I just got the regular stuff, but they did have more expensive heavy duty stuff. The plain gasket paper (almost like a cereal box cardboard) works fine if you seal it on both sides with high temp orange RTV. (not worth a crap if you do it without RTV though - it will blow in a day)
