Re: Weird Gas Cap I drilled a tiny hole in the underside of the cap, near the middle, then another but on the side on the top for ventine, that way it kind of goes in the hollow of the cap, then back into the tank.
I also fill it so it's a half inch or so below the opening when it's on the kickstand.
Take off your gasket and go to Home Depot or other and find thicker washers that work better, in the plumbing area.
