Originally Posted by Biker Mike I shut the fuel valve off while riding and once it started running out of gas (leaned up) the sputter went away.  |
Definitely sounds too rich then. What elevation are you at?
Where is the clip set?
What pre-mix ratio are you running?
Is it possible that you've run it rich/long enough to have partially plugged up the exhaust baffle?
