  #23 (permalink)
Old 03-24-2008, 11:13 PM
Egor's Avatar
Egor Egor is offline
Default Re: bicycle engine total tear down
10/4 that is what I think also. I have the one like yours in a Schwinn cruiser, the avatar. That bike has the most vibration but it has the worst mounts also. I have the diamond frame bike with a Dax engine and that has the removable weights, also the best mounts but still not the best for smooth. The bike I call the Green Hornet is as smooth as a good motorcycle also a Dax, I am thinking the mounting is an important factor, I am going to do an extra plate to pick up the bottom of the engine on one of the bikes to see if it helps. Working for Honda years ago there was a problem with the MT250 the motor mount was in a bad place and would crack and then would just about tear the bike to pieces welding was not good, the metal was so brittle it would just crack again, very hard to fix. Thanks for being a good sounding board, if I talk things through I solve the problem. These engines are a good place to relieve tension. I have not had a problem with the weights coming loose yet. Have fun, Dave
