Re: Is there a proper way to adjust the float in the (toilet) carb bowl? well beats me but it seems the only place left for air to infiltrate. BGJ thinks so as well. I think I would lift the jug seal it with sealer and try it again. Unless norman tells you not to use sealer. Seal on both sides of the gasket. You can probably do it without removing the jug. just lift it a little and do the seals. |
