Re: Is there a proper way to adjust the float in the (toilet) carb bowl? well the only think I can think of is when you pulled the head, you took pressure off the bottom gasket. If it separated it might have torn it. That would cause a small leak. The head gasket controls compression but the butt gasket seals the jug I think. Air might pass the rings from there I suppose.
Did you notice if the butt gasket was glued I can't remember if mine was or not/ |
