  #22 (permalink)
Old 03-24-2008, 11:13 PM
Pablo's Avatar
Pablo Pablo is offline
Default Re: Is there a proper way to adjust the float in the (toilet) carb bowl?
Originally Posted by deacon View Post
yes sounds like a leak.....
Okay you sealed the manifold joint
you sealed the manifold gasket
you tightened the carb screws
so where else could it be leaking...
Head gasket
butt gasket
have you ever removed the head or even loosened it.
I had the head off when I flooded it out when I first got it. I did reuse the gasket but torqued it properly - and there are no signs of a gross leak and compression is very tight. I suppose it could leak when hot. But at higher RPM with partial choking it was running fine......could have not been hot enough to leak...hmm.....Well I did order a new head gasket, just in case. I'll do Norm's glass plate and Al paint techniques....
Butt gasket - it does not appear to be leaking, but why would a leak down there cause such a problem? Why is the but seal anymore critical than the case half (down the center) seal?
