  #19 (permalink)
Old 01-09-2009, 07:35 AM
happyvalley happyvalley is offline
Default Re: Just a thought Nuvinchi hubs
Originally Posted by Clotho View Post
As an example I have 2 bikes that are very similar. Both have 70cc (true) motors with the same hp modifications right down to the same style expansion pipe. Both have street tires and are well maintained. The biggest difference between them is that one has a Nuvinci hub and the other has a conventional derailleur. The Nuvinci bike has more top end and accelerates better.
Good stuff. It's great to see some actual side-by-side experience cited as empirical evidence.
How are you transferring power from the engine to the rear wheel on the two bikes, left side drive sprockets or a jackshaft to the drive train?
Reading through the comments on the hub blog you linked I thought this was interesting also:
July 25, 2008 at 12:09 pm
Switching from derailleur to shimano nexus -8 has reduced my average speed on a 14 mile commute by 6%. This indicates an efficiency reduction of over 15%, considerably more than you state above. We are getting definitive efficiency measurements done for greenpower electric car racing & I will try to post results here. Results from that forum suggest that the Nuvinci CVT is significantly less efficient still. Note that the shimano alfine now has roller bearings on its planet gears and their advertising proudly boasts “our most efficient hub yet”. With those bearings & OEM grease replaced by automatic transmission fluid, this hub might get up to rohloff standards for efficiency, which would be a profound improvement!
