Old 03-24-2008, 11:15 AM
Pablo's Avatar
Pablo Pablo is offline
Default Is there a proper way to adjust the float in the (toilet) carb bowl?
Continuing my saga……..(from the realm of electrics to fuel)…………
Is there a proper way to adjust the float in the (toilet) carb bowl? Easy way?
Right now I have Norm's chalk board warning! (Yeah I know ) A factory setting that didn't work. Heavy fingers and needle nose pliers.
To Recap:
1) Factory setting, suspect float too low - not enough fuel ready to go. Open slide via twist throttle - too much air, not enough fuel on immediate demand. Not a matter of too rich or too lean.
2) Open carb up, tweak float "arms" apart. (see Norm's drawing). Problem gets worse.
3) Open carb up, tweak float arms together. Get Exxon Valdez of premix fuel in the garage.
4) Open carb up, tweak float arms apart problem still there, but better.
So today, this afternoon: Just bring the arms together a hair……it's a fine line and I need some input……..
Paco and his faithful black dog Chancho thank you immensely.
