Re: How tight should I tighten the sprocket bolts? Follow our instructions and you will be successful if you don't understand anything don't be afraid to ask. I use the fiber gasket on both sides to get a good grip on the spokes, keeps the sprocket off the spokes, provides space to aline the front and rear sprockets.
Norman
