Looking for lower case housings The woodruff key rattled out on a friends bike and knocked a hole in the flange on clutch side of his motor. The vendor he got his kit from is not willing to fix the issue.
Attached is a couple of pics. Damage was caused by a galled screw thread on the crankshaft pinion that did not tighten up properly and allowed the pinion (sometimes called bevel gear) to float and the woodruff key to come loose.
Does anyone know a vendor with the lower unit in stock?
Thanks!
James |
