Re: For what its worth.Serial# 001 HI,
Which motor are you running that has the front motor mount that is an integral part of the motor?....I've installed motors in very tight situations where the removable front engine block had to be chopped (the flat back side) so the motor would fit....I guess one could grind out the front mount in those situations if the front part is solid....Hmmm ....maybe it's not such a bad thing after all....
Andrew |
