Originally Posted by Norman Pablo you got a buddy with a good engine ignition coil box to try? Did you take a look at the mag coil under the cover the wires could be damp or the soldered connections might be lose or you could have some metal particles touching the wiring and occasionally shorting things out. You haven't washed the bike off or got it wet lately did you? Out in the cold and then brought into a warm place or vice verse.
Lowering the needle will lean it and rasing the needle will make it richer
But you said the plug is wet and it cuts out if it aint the cdi black box it must be fuel related.
I don't have the ohm reading on the cdi maybe we will get someone to jump in that has these reading handy. If not I could check mine and get back to you.
Don't give up.
Norman |
Thanks Norman - to know me, "give up" is not in my soul or genetic make-up!
My bike buddy is to far away - about 100 miles - but we had discussed swapping carbs, cdi's, etc and such, just to see.
Please - I would love the ohm readings on the coil.
I will open the mag coil area and have a look-see.
Indeed - moving the E clip up lowers the needle and makes it leaner.
