Re: Product Review....Dax Muffler you might need to go leaner being at higher elevation. Try the wide open run after its warmed up good. While at wide open and wound out push in on the kill button and keep it pushed in to kill the engine. Pull the plug and see what color the thing is light brown is good . If the plug looks like a new one no color or the electrodes are blue its too lean, nasty black and oily, its too rich. If its not broke in yet it will be kind of hard to do a plug check. I can't remember the clip setting but I think it is slot #2 from the top of the needle but check my post on carbs to be sure. Does that help you. If not take a picture of your plug in good outside light and I'll try to give you more help.
Norman |
