  #12 (permalink)
Old 11-29-2008, 08:41 PM
DetonatorTuningSolutions DetonatorTuningSolutions is offline
Default Re: Changing crankset to 3-piece
Originally Posted by pi-rat View Post
cant you make this into a shifter kit by putting a #420 chain sproket on the left side so it will spin te gears on the right? if it works ive got a 21 speed motorbike !!!! i think that i might have to cut off the pedals for it to work though and put a case over it so i dont cut off my leg on the chain and sproket.
yep, jack sahft shifter setup with out the jackshaft.
you'll need to asses the power and torque of your engine to calculate the primary reduction needed form the engine output to your lefthand crank sprocket. it also depends on what speeds you want to achieve.
don't forget some sates require the pedals, be sure to check your local laws.
steve
